OK, I will start by confessing to being more than a bit obsessive about this. I am currently working on my sixth build, and am really trying to get this one right.
Components include:
Thermaltake Tsunami Dream case
OCZ Modstream PSU
DFI NF4 Ultra D mobo
AMD Opteron 165 (dual core)
Zalman 9500 CPU cooler
Zalman VF700-CU VGA heatsink
6800GS video card
Thermaltake Hardcano (my third attempt so far at a fan controller for a screwless case)
Geil One RAM (2 x 512)
Maxtor 250G SATA HD
Liteon CDRW and Samsung DVD-RW
I have managed stable OCs of as much as 50%, but temps and noise were more than I want to live with on a daily basis. Still, I want the interior of my case to be as clean as possible, both for airflow and for that big blacklit window on the side.
This is my second modular PSU, following an Ultra in a rig I built for a stepson. I like the idea of modular a lot, in spite of the theoretical performance limitations. Too many non-modular PSUs just have an ugly mess of unsleeved wires to dispose of. Even sleeved PSUs (tried that too) don't do that good of a job from what I've seen.
My problem with modular cables is that they are too thick and too long. The back of my PSU is about 6 inches from the back of my optical drives. The shortest molex to molex power cable is about 20 inches long. That leaves a lot of very thick and very wasted wire, and I have not had much luck finding a useful home for it. With the exception of the PCI-E cable, every one is longer than it needs to be in my rig. And when I finally get my 6800GS back to the slot it belongs in (long story) that one will be too long, too.
Since the Modstream has molex connectors on one end of almost every cable, and on both ends of several, it seems to me that by making my own cables I could solve some of these problems.
I have a lot of questions, and am not sure they will be in any particular order:
1. Is there a place that sells all the different connectors? I do not have the guts to try the 24 pin connector (and it is not modular on the Modstream anyway), but I do not think I can hurt much by attempting the others, so long as I connect the wires in the right order. Can I buy individual examples of any or all of the following connectors: PCI-E, SATA, mini-Molex (aka floppy power connector)? What about the 4-pin mobo power connector (though I am not sure as I write this if it is modular on the Modstream or in the same wire bundle with the 24 pin)?
2. How about a good wire source? Is 20gauge OK for these very short runs, or should I go with 18G? I am thinking high purity copper with highly flexible (teflon?) sleeving, or something of that sort. Is there a good computer supplier, or should I look to a hi-fi source like The Parts Connection?
3. More generally, is there a one-step shopping source for a project like this? The machine is up and running now, so I do not have to be in a hurry, and am willing to use multiple sources if necessary.
4. What is the best sleeving type, for flexibility, durability, and ease of use?
5. I've seen many tutorials on removing and replacing molex connectors. Is there something similar for PCI-E, SATA, or mini-molex connectors? URLs, please.
6. Has anyone else made their own Molex terminated power cables from scratch? Just how do you deal with putting a single Molex on the PSU end and two or more on the receiving end? Daisy chain? Or a Y split earlier on?
7. Is the following understanding of how Molexes work correct? The two outer holes are for 12V (one power and one ground) and the two inner holes are for 5V. Right?
8. If #7 is correct, can I do the following to make my connections neater and simpler? I'd like to create some 12V only connectors and some 5V only connectors. That way, I'd only have to run two wires to each molex rather than four. I realize that makes these cables largely non-transferable to other applications, but I am concerned about getting this box right, not the next one. I could use one modular power source to run some very short wires to the pair of 12V inputs on my optical drives. On another power source, I'd run only the inner wires to the 5V inputs on my floppy and on my DFI mobo (though I still do not understand why DFI considers that separate 5V input so important). Am I correctly understanding how this works?
I'd really appreciate it we could get a discussion going on this. I've seen talk about sleeving and replacing molexes, and this just seems to be the next logical step to me. It has probably been discussed somewhere, but I have yet to see it.
Please advise and instruct me.
Thanks,
Phil
Components include:
OCZ Modstream PSU
6800GS video card
Maxtor 250G SATA HD
Thanks,
Phil
