Alright. Last night I wrapped some wires with mesh sleeving and heat shrink, and it looks great! I'm getting parts for a new computer now, and next weekend I'll be getting my new case. When the case comes in, I'll be taking my PS out of my current rig (a 435W Dark Blue Enermax) and sleeving all the ends. The problem is finding a Molex pin remover that works AND doesn't cost an armand a leg. They're not easy to work with, I can tell you that. I found that on 3-pin fan connectors, you can bunch up the weave in the mesh sleeving, kind of like Chinese handcuffs (don't take that personally, I don't know any other names for them), and get even 1/4" wrap around them. It's quite nice. You can see an example of what I'm talking about on
this page.
It looks EXTREMELY nice! However, a word of warning. I almost messed up some of my work, but realized my folly in time. I have a 3-pin connector on my Panaflo that is custom made to plug right into the fan and the header on the morhterboard without having to splice into the bare ends that the Panaflo comes with. I was putting sleeve wrap on it when I realized that if I put it too close to the side that connected to the fan, I wouldn't be able to get the wires into the guide that fans have. You know, the groove on the side of all fans that kind of hold the wire in place? Anyway, I plugged the wire in and secured it in the groove before cutting the mesh sleeving and using the heatsink.
When all was said and done, this looks REALLY nice compared to bare wires. I only use split loom when it's completely out of site (behind my OTHER god box, for example) because it doesn't look as good, and I think that the spiral wrap doesn't look as good as this either. IMO, it's worth the time.
EDIT: Don't want to spend $40 to clean up your case? You might want to look
here for sleeving. Prices are:
1/4" _ _______ $0.41 / foot
3/8" _ _______ $0.55 / foot <------- This is available in Black, Grey, and Blue
1/2" _ _______ $0.58 / foot
3/4" _ _______ $0.65 / foot
1 1/4" _______ $0.89 / foot
And to think, Civic2oo1x spent $2 / ft and I paid $1 / ft before. This is a little more in my range. Just in case I sound like a commercial, I don't have any idea who these people are, I just did a Google search for cable sleeve and they came up.
