Cable Snakes for XLR...
Possessed Freak
I really hope this forum can answer this one.
Okay, this is a semi simple question, just need a yes or no.
I *might* have to run my own snake for an auditorium setting. The distance will not exceed 150 FT. I would like to permanently run this cable in the ceiling, which means it must be plenum.
I ran across this cable: http://www.clarkwire.com/712-PLEN.htm
Am I correct to assume that I can use the drains as Pin 1 in the XLR and I could get 12 channels of balanced audio out of this cable?
