Cable Routing Suggestions
zonkie
113
Finishing a build and not sure where to route the video card power cords. I may add a fan later in the spot to the right of the bottom mounted power supply. It would be blowing air right where I currently have the video card power cords going.
So is it good as is or should I route them above the video card and then over?
mfenn
22,400
www.mfenn.com
You could probably tuck them between the video card the motherboard tray for a slightly cleaner look, but it seems that you have the right idea.
