Cable question
RLGL
I am in the process of running cable to an outbuilding for WiFi. The total run from the router in the house to the building will be about 200 feet. I will connect to another router. I have 5e cable.
The question: Do I wire the cable as straight through or as a crossover cable?
TIA
Dave
Newer routes are auto sensing so straight through will work fine. I haven't needed a cross over cable in a very long time.
Straight through is fine, especially between two switches/routers. The main concern is how you will be grounding the exterior wiring.
The out building is on a separate meter, up to code. (8 foot grounding rod off the panel).
Both the house and out building have 200 amp services.
