X Xray71 Junior Member Sep 16, 2004 6 0 0 Sep 20, 2004 #1 Can anyone suggest some cable clips to organize the mess inside my case?
C CraigRT Lifer Jun 16, 2000 31,440 5 0 Sep 20, 2004 #2 zip ties! you might want to also look into rounded IDE cables, and maybe looming your power cables. makes it a lot cleaner.
HardWarrior Diamond Member Jan 26, 2004 4,400 23 81 Sep 20, 2004 #3 Originally posted by: Xray71 Can anyone suggest some cable clips to organize the mess inside my case? Click to expand... Just plain zip ties are fine. If you can, buy some molex extensions and run as much wire behind your mb tray as possible.
