Just hooked up SurfBoard SB4101 through Comcast. Very fast connection. Connected to my SMC Barricade Router. All PC's on network have access to the connection. All PC's are running Win98SE. I have DHCP enabled on the router. Just hooked up the connections (Ethernet & cable) and away it went! How important is it to install a software firewall with this configuration? I have ZoneAlarm, but not installed. Will the Barricade stop incoming traffic from nefarious individuals without ZoneAlarm, or would it be best to install it?
