Cable Signal Details
Forward Path: Return Path:
Signal Acquired at 561.000 MHz Connection: Acquired
SNR: 38.3 dB F requency: 26.5 MHz
Received Signal Strength: -8.9 dBmV Power Level: 48.0 dBmV
Bit Error Rate: 0.000 % Channel ID: 3
Modulation: 256 QAM Modulation: QPSK
The results I got above, are from cable modem diagnostics that I ran, because I feel I am having some issues with (stable) connection speeds. is my SNR too high? or is my RSS too high or too low ?.
I have roadrunner (cable) internet.
5Mbit Down
384Kbps Up
Modem : RCA DCM425
could someone help me if those levels arent optimum , on how I would go about correcting the problem. thank you
5Mbit Down
384Kbps Up
Modem : RCA DCM425
