Originally posted by: Malladine
The NIC's fine, the modem works, cable's fine...must be the ISP!
Have you changed the cable? Or are you still using the one they gave you?Originally posted by: Malladine
Thanks guys, didn't think so.
Ojai, I basically wanted to know if I could connect the cable modem directly to the pc using ethernet or if I had to have a router between them.
