Hi folks,
Working on a network installation for a friend, and I'm absolutely stumped. They're running WinXP Home with SP1, and besides device drivers that's the only software currently installed (said friend just did an fdisk and format with a clean installation of the OS). Here's the issue that I've run into: when connecting the cable modem directly to the computer via ethernet, I can't hit the ISP's DHCP server. If I connect the modem via the USB port, it works just fine.
In an attempt to eliminate some variables, I've replaced the cable modem with a new model from the ISP's list of recommended products, and registered the MAC with the ISP. Same issue- no dice with the ethernet, works fine with USB. I also attempted to access the internet from my laptop by connecting it to the modem via ethernet (to eliminate the NIC as a problem), and was unable to connect to the DHCP server. I don't think there's anything software related jamming up the works, since we're working from a clean installation of the OS. I contacted the ISP's tech support, and they indicated that everything on their end is working OK.
I'm stumped, and would be extremely receptive to any advice or information you might have... I'm about to start ripping hair out over this, it's so frustrating. Thanks!
