Cable Modem and Router help!! (Please!)
Eric G.
36
I have a Motorola (General Instruments) SB3100D cable modem and a Linksys BEFW11S4 Wireless router connected. When I connect the cable modem directly to the computer via Ethernet I can access the modems web page at 192.168.100.1.
My IP address on my computer is 192.168.1.101 (static, no DHCP)
When I try to connect to the cable modem through the router (Router is set at 192.168.1.1) I cannot access it.
Here are my settings on the router:
Setup Password Status DHCP Log Security Help Advanced
SETUP This screen contains all of the router's basic setup functions. Most users will be able to use the router's default settings without making any changes. If you require help during configuration, please see the user guide.
Host Name: (Required by some ISPs)
Domain Name: (Required by some ISPs)
Firmware Version: 1.40.2, Nov 28 2001
LAN IP Address: 192.168.1.1 )(Device IP Address)
(MAC Address: 00-04-5A-FD-3D-37)(Device IP Address)
255.255.255.(Subnet Mask)
Wireless: (MAC Address: 00-90-4B-07-D6-53)
Enable
ESSID:
Channel: 11 (Domain: USA)
WEP: Mandatory
WAN IP Address: (MAC Address: 00-04-5A-FD-3D-38)
Specify an IP Address . . . 192.138.100.2
Subnet Mask: . . . 255.255.255.0
Default Gateway Address: . . . 192.168.100.1
DNS(Required)
1: . . . (not available yet)
2: . . .
3: . . .
Login:
PPPoE RAS *Disable*
NOTE: PPPoE is for ADSL user only.
RAS is for SingTel ADSL user only.
User Name:
Password:
RAS Plan: 512k Ethernet
Connect on Demand: Max Idle Time Min.
Keep Alive: Redial Period 30 Sec.
Host Name:
Login:
Disable
LAN:
Subnet Mask: 255.255.255.0
DHCP server: Enabled
WAN:
IP Address: 192.168.100.2
Default Gateway: 192.168.100.1
DNS: 0.0.0.0
0.0.0.0
0.0.0.0
Anyone? The cable company is going to be here on Wednesday to connect the cable modem service.
Eric
