cable management
surfactant
107
Is there a system to organize multiple cables running the same way. I don't want to nail them to the baseboard. They are coaxial, cat5/6 cable and speaker wire. Is there a possible a loose coil system (like those used in cases to mange the wires) that these cables could go into. Is there any chance of interference putting them close together. Mark
chsh1ca
1,179
Zip ties that have been pulled taut and clipped, then hold it in place using whatever fastener is in place now? Or maybe just run the cabling through the wall, if that's an option. ;)
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
Panduit has some adhesive duct / channel / raceway from ~1" and up.
Home Depot has some channel, possibly Panduit. It's usually in the electrical dept near the long power strips.
Good Luck
Scott
