- Dec 26, 2004
- 11,905
- 148
- 101
Well... after alot of hours and alot of frustration.... it's finally complete for the most part. I still need to zip tie alot of things and clip some things down and they are being delivered tomorrow, so I did what I could today. I installed the XP-120 with a Panaflo on it, replaced the rear exhaust fan with a Nexus fan, put some tubing in just a little for now -- more will be in tomorrow when the zip ties and things come. And also I cut off the "filter" stuff on my side panels, because it didn't do much. I'm real satisfied with it, except with the filtering stuff off it's a little louder, but that's fine with me
Pictures as it stands now:
Main1
Bottom1
Bottom2
Inside1
Back1
Complete
What do you guys think of it as it is right now? Do you think I should use some of the tubing up top with the powersupply connectors or leave it as is? The case really doesn't have alot of places to hide things like the P180
More pics will be up tomorrow night probably... When everything is said and done.
Main1
Bottom1
Bottom2
Inside1
Back1
Complete
