Cable Management Tips?
adamb10
8
The inside of my case:
Any tips to make it less cluttered? I tend to be horrible when it comes to cable management.
zagood
4,102
When you can, route wires behind the motherboard tray. Whenever a new case comes my way I'm always ready with the dremel to add access to the back of the tray.
Use zip ties and zip tie anchors to keep wires along the edges.
Use extensions for anything you currently need to route over the motherboard because the wires are too short to reach by going around a different path.
Get a modular PSU.
Imp
18,828
184
Zip ties, twisty ties, tape, Antec P18X with which you can route stuff behind the mobo.
RockinZ28
2,171
49
101
I used to be the same way, but Corsair's cases with a modular psu make me look like a pro.
http://www.corsair.com/cases.html
Maybe look for a used one on the forums if you don't want to spend much. I picked up a barely used 600T today for $50, even though I already have one.
jimhsu
705
Some tips:
- Zip ties, cable ties, velcro ties, sleeves, clamps, basically anything that can hold two things together. Be creative.
- Try to run things parallel and perpendicular to one another for neatness.
- Put as much stuff as possible BEHIND the case.
- Take advantage of any nooks or crannies that you might find. Might need longer wire to compensate for routing.
Pics of half-completed build. Cleaned up cables some more after this:
Incidentially this is the first build which I'm satisfied with the wiring so far.
Case is Thermaltake Element G. Makes cable routing a snap (see 2nd picture). All that stuff is in the back; you just can't see it.
Having a high-quality PSU also helps. That thing at the bottom is a Seasonic X-560, with fully sleeved and modular everything. Definitely does help, if you don't want to sleeve cables yourself.
Daemas
206
custom length wires. being able to cut off slack/add a bunch of length is what makes/breaks those insane modders chance to get paid for that shit.
BoomerD
66,718
15,117
Here's my latest build.
I still need to replace that one crappy looking IDE cable with something a bit more attractive...
(no, I really don't want to take a pic of the "other side." it's still kind of messy.)
Doggiedog
12,780
Wow! I wish I had you guys to help me with my builds. Even the OP's wiring looks better than my latest build. It's so bad I have to carefully close my case so that none of the cables stops any of the fans inside.
Indyboy2
317
Nice Job BoomerD very neat.There are alot of others here that do beautiful work also .I like Rubycons rig and a few others .To the op just look at all the pics of the rigs here and take what you like from them take your time once you get going its kind of fun and in the end its looks good and cools better.
Nightrainsrt4
A case with space behind the motherboard tray definitely helps. Patience and determination also are very important. Zipties, cable mounts / ties, anything similar you think would help.
Also, RIT Dye if you don't want to sleeve. Less than $2 and your time. The intel heatsink wasn't dyed as it was replaced very soon afterward.
StinkyPinky
6,993
1,284
You and me both :oops::$
adamb10
8
I rewired my PC and ended up with this. Since this image was taken I also re-routed the 8 pin connector underneath the video card.
Dec 26, 2007
11,782
I'm getting ready for a new case (same system, but got the Lian Li V1020R), and have a few things I'm doing.
First is using micro velcro ties, and those little mounting points with the sticky back in specific spots based on a drawing of planned cable routes.
Second is cable sleeving. I got stuff from performancepcs.com (individual sleeved cables) which will help keep everything looking clean.
Third, is time. I'm planning on this weekend spending a few hours working on cable layout and routing.
Finally, and more long term, I'm going to get sleeving from http://en.mdpc-x.com/ (great looking sleeves), and sleeve things. I'm at work, so I can't find the actual picture but it's in this thread (http://www.xtremesystems.org/forums/showthread.php?t=202639&page=83), and somewhere around that page. Basically it shows a PSU that has been sleeved from where it is output, starting off with all cables in one group and gradually breaks them down to eventually the individual cable. Here is a sample of the end. If you then imagine that 2-3 of these get bundled together in a sleeve, then 2-3 of the large bundles get bundled together you'll have an idea of what I'm doing.
UHAF&
Nightrainsrt4
That's seriously brilliant. Great idea!
Thanks. It chemically bonds to the wire and plastic of the connectors so no worries of it rubbing off.
All the wires in the case were your typical red, yellow, orange psu wires. The sata cables were done as well as those were the typical red from older Asus motherboard and yellow from a Gigabyte board.
It has been running as my server well over a year now 24/7 with absolutely no problems. Just had to make sure everything was properly rinsed and dried overnight before reassembling.
