Cable Management Question?
RobDMB
434
On some abit motherboards the floppy connector is on the bottom of the motherboard and not on the side like most motherboards. I was wondering if there would be any adverse effects if I used a long Floppy cable and actually ran it under the motherboard? Would this cause any problems or is it ok? Thanks, Rob
Zap
22,377
7
Should be perfectly fine. I've done some creative routing behind the motherboard like that with drive cables, fan wires, etc.
letdown427
1,594
No problems at all, I'm upgrading mobo soon, and will be routing a lot of little wires under it, fan wires mainly.
