imported_intrepid
Okay, well I just got the last components of my computer today and I put it together, no problems. But alas, the inside is messy as hell. I just wanted to ask if it's okay grounding/static electricity wise to use masking tape to tape some of the cables to parts of the case to keep them out of the way. Or, if you guys have any better ways to do it, I would like to know.
Also, I only had six of those copper motherboard mounts (the ones you screw into the case and then you put a screw into the mount). However, my motherboard has eight mounting holes. Is it safe to neglect the other two as long as the thing doesn't tip over?
