Originally posted by: Eli
Sounds like a job for...
YOUR ISP!
Call them.
Originally posted by: nsafreak
Either something is wrong with the modem or something is wrong with the cable coming into the modem. How many splitters are before the modem? Does the cable TV reception look good?
Btw wrong forum.
Yeah I would probably say new modem time. The Motorolas are highly recommended.
I have Cox Communications and it has never been down for the year and a half that I have used them, except when Ivan came through and everything was down then.sounds like you have Cox Communications..
No, Comcast
The connection light blinks when it is out and stays solid when it is on.
Im using a old 3com sharkfin modem.
Is the modem bad or is this normal for cable connections to shut off and on?
Originally posted by: RedCOMET
I had a comcast branded cable modem crap out of me after almost 4 monthes of service. The tech came out, replaced the modem with a motorola , and it worked.
