A adams828 Senior member Nov 29, 2003 486 0 0 Jan 8, 2005 #1 how can i find what cable i need to i camn move the antenna for my pci wireless card AWAY from the back of my pc? i have a netgear 311T PCI card thanks!
F fireontheway Golden Member Jul 8, 2003 1,480 0 0 Jan 8, 2005 #2 Your description is kinda vague,but is this what you're looking for D-Link ANT24-0400 2.4GHz Omni-Directional Indoor Antenna? It will replace your regular antenna and place it where you find the signal the strongest.
A adams828 Senior member Nov 29, 2003 486 0 0 Jan 8, 2005 #3 Yeah that is exactly the type of thing I'm looking for. Will this work with my card though since it's a Netgear? (In terms of the cable connection)
F fireontheway Golden Member Jul 8, 2003 1,480 0 0 Jan 9, 2005 #4 It should work, according from the 2nd user review in the link he used it with a WG311T.
