cable descrambler problem
zogg
960
I was using a coolbox avenger on my cable tv with analog signal and it worked great.
Recently I was switched to digital cable tv svc and could no longer use my descrambler.
OK, I sold the box to a friend and set it up for him and all was well.
Later that week he called and said that he kept getting a burst of whitenoise and static and he couldn't clear it. I never had that problem.
I went over there and he turned on the tv and nothing went wrong it was working perfectly. He called again to say the same thing happend. I went over there and noticed that when the signal went to pure static I moved the cable around on the back of the tv from the descrambler and the signal cleared up.
Now he says it always happens and insists its not the cable.
The box is bullet proof but I dont know if it is surge proof.
Could a surge cause the descrambler to go into pure white noise in sound and video?
Or could a week signal cause that intermitantly?
any ideas?
pyrojunkie
243
Weak signal, bad cable, bad power to descrambling device, loose coaxial connector on TV or device. I don't believe power surges have anything to do with this problem.
xSauronx
19,582
4
"hi i need help with my cable theft device"
isnt a descrambler a theft device? it was last time i knew somebody who had one...
leave your theft questions off these forums please, honestly
zogg
960
THANX pyro
Its only a theft device if you use it for theft purposes...the box has provisions to blockout all channels that aren't prescribed so.....................................................
bite me xSauronx :evil:
pyrojunkie
243
Descramblers are legal if used properly. The cable company used to be able to overcharge on the equipment until the FCC stepped in and opened the market for any descrambler.
A gun is a killing device, but its legal to own one. If someone said he had trouble using it, would you jump all over him too for using his killing device?
