Cabinet with SMPS needed
rohitshakti
44
I want to purchase a new pc with following conf.
How much power do i need for it.
Intel E5200
G31 mobo
2 x 2 gb kingston
GT 8600 graphic card
500 gb hdd
sony dvd -writer
15" monitor (i hv)
HOOfan 1
2,337
15
Originally posted by: rohitshakti
Pls suggest me a decent & cheap cabinet and a smps for the above within 1500
1500 what?
Why does it have to be a case with a PSU? Can't you buy them separately? The PSU is the easiest componente to install in a case....
How about this comes with a 380W earthwatts PSU. for $120.
HOOfan 1
2,337
15
Indian Rupee? According to my conversion table, that is only $30US. You will hardly find a case WITHOUT a PSU for that....you need to up your budget to around 5000 Rupees
rohitshakti
44
But that is the max budget i hv for the cabinet and smps.
Rather it would be great if u could just tell me some good smps in 20$.
HOOfan 1
2,337
15
Sorry I can't help you, there are no decent Power Supplies out there for $20. I won't condone someone cheaping out on a power supply and I certainly won't suggest some cheap piece of crap.
Modelworks
16,240
7
Hoofan is correct. You can't say my budget is $30 so there has to be a good case+power supply for that. You are going to have to save up and get something better.
WaitingForNehalem
2,497
They'll do just fine for his purposes. My P4 X850XT is running on a 500w Raidmax that came with my case just fine. There is no need for a high-end PSU on low powered builds.
HOOfan 1
2,337
15
There is no need for a high end PSU, there is need for a PSU that isn't absolute junk....which those are.
WaitingForNehalem
2,497
Because we all know that his build needs a PSU with the lowest ripple and highest efficiency. :roll: rohitshakti, those PSU's will do just fine.
HOOfan 1
2,337
15
He does need a PSU that won't blow a transistor though, there is a distinct possibility of that happening with a PSU bought with a $30 case.
Hell it is his money, if he wants to take poor advice and buy a gutless wonder, no skin off my back.
