Cr0nJ0b
I have a cabinet project that I'm starting and I'm just not sure what material to use. I would really like to do this in wood, since I have the tools and can do it without help, but I'm not sure that wood would be strong enough.
The basic idea is this. I have an open cabinet 54"(W) x 56"(H) x 29"(D). I want to build a door to cover the opening, so a 54" x 56" door.
Here's the tough part, I want to hand a plasma on the outside of the door, so it has to handle the torque from the materials as well as about 90lbs of plasma TV.
My initial thought was to use a hard wood (oak?) 2 x 4 with like 6 door hinges on the right side. Then build a frame with 2 x 2 (oak or hardwood) around the edges. I would have across beam in the middle and diagonal from the top right to center left and center right to lower left. Sort of like 2 "Z"s on top of each other.
The whole door would move as one piece.
I thought about putting some 1/2" plywood on the back for more strength, but think that will add too much weight.
My worry is that with the weight of the material and the 90lbs of TV, that wood is just not the way to go...but again, if it's possible, it's my preference. My guess was the material weight might be 100 lbs.
The alternative would be to have the frame build our of 2" steel pipe and secure it on all sites, like a door and casing all from steel... I would build the wood on top of the steel to match the other cabinets.
thoughts?
thoughts?
