crackshot91
I have an e6750 oc'd to 3.2GHz (400x8/1.22500 vcore) My memory is G.Skill DDR2-800MHz RAM (5-5-5-15 Timings at 800MHz) My mobo is a Gigabyte GA-P35-DS3L Rev. 2. My CPU is 100% stable at the above OC, but I'd like to get it to 3.4GHz. I used Intel Burn Test to verify stability (10 runs @ High setting) My CPU's max temp at the above OC was 48c CPU/53c on each core. I raised the FSB to 415x8 (3.32GHz) and bumped the vcore up to 1.27500 the ram was set to 2x (830MHz 5-6-5-15 Timings). I tried the burn test and it failed after 432 seconds. I tried memtest and it was stable for ~4 hours at 830MHz/5-6-5-15. So I bumped the vcore up a notch to 1.28500 and it still failed. finally, I tried 1.30000 and ran the burn test once more and it failed yet again. The temps never went above 55c for the CPU and 60c for the cores. Is there something I'm missing?
