junglerecker
Hi Everyone,
This is my first time custom-building a computer, actually I'm gonna let the computer store down the street build it, since I don't trust my wiring/ soldering expertise, but it's the first time I'm selecting all the components myself.
Please let me know if you see any major hiccups in my choices. Thanks!
-James
ASUS P5B Deluxe/WiFi-AP Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard
Intel Core 2 Duo E6600 Conroe 2.4GHz 4M sharing L2 Cache LGA 775 Processor
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel Kit System Memory
GIGABYTE GV-NX76T256D-RH Geforce 7600GT 256MB 128-bit GDDR3 PCI Express x16 Silent Pipe II, Lead Free Video Card
NEC Black 16X DVD+R 8X DVD+RW 8X DVD+R DL 16X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache IDE/ATAPI DVD Burner
Pioneer 111D: Black 16X DVD+R 8X DVD+RW 8X DVD+R DL 16X DVD-R 6X DVD-RW 16X DVD-ROM 5X DVD-RAM DVD-ROM 40X CD-R 32X CD-RW 40X CD-ROM 2M Cache ATAPI 16X DVD±R DVD Burner With 5X DVD-RAM Read
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
PC Power & Cooling 510 SLI-PFC ATX12V 510W Continuous @ 50°C Power Supply 90 - 264V UL/ ULC/ TUV/ CE (I know, I know... it's overkill. BUT if I overkill anything I want it to be the PSU, so surges/brownouts don't kill my PC!!)
OPTI-UPS Enhanced Series ES1000C 1000VA 700W 8 Outlets UPS
Antec Performance I P180 Silver 0.8mm cold rolled steel for durability through the majority of chassis, 1.0mm cold rolled steel around the 4x HDD area ATX Mid Tower Computer Case
SAMSUNG 204B-BK Black 20.1" 5ms LCD Monitor 300 cd/m2 800:1 0.255mm Pixel Pitch 1600x1200 display (I'm not crazy about this monitor, but it's the best I can find, for the money, with that resolution that's not widescreen)
2X COOLER MASTER SLC-S41-U1 40mm Blue LED Light Chip Set Cooling Fan/Heatsink
Does anyone recommend buying extra fans for cooling? And if so what brand?
-James
