I was going to replace my stock Intel heatsink as well as start overclocking my new 6420, but first I wanted to make sure I had an accurate way of gathering temperature information.
There are several temperature programs out there and I have tried them all out. The results seem to match up between all the programs, but the one thing that still has me confused is the fact that my Tjunction temp is lower than my Tcase temp.
From what I have gathered, Tjunction is suppose to be higher than Tcase by 15C +/- 3C.
I have been using TAT, SpeedFan 4.32, CoreTemp .95 and the Nvidia monitor to look at my temperatures.
TAT, CoreTemp and SpeedFan (Core0 and Core1) are suppose to be the Tjunction temperatures.
The nTune monitor, SpeedFan (CPU), and the bios temp should all be the Tcase temperature.
Idle: Tcase temp is ~41C and Tjunction is ~33C.
Idle
Load: Tcase temp is ~62C and Tjunction is ~56C
Load
I have seen some other posts with people having the same issue on other forums as I and the answer seems to be to simply change the offset of the Tjunction reading in SpeedFan so that it displays correctly. This doesn't seem like a fix to me though, because I still know that the temperature is not reading correctly. Plus, doing this seems like you are just making a best guess as to how much the temp is off.
Does anyone else have a similar issue with the 6420? And can anyone explain which temp I really should look at in regards to overclocking?
Thanks 🙂
C2D e6420 Stock
EVGA 680i
Idle
Load
Thanks 🙂
C2D e6420 Stock
EVGA 680i
