'C' Programming- Format string help.
CM4
64
What would be printed by the code fragment given below? Please could someone explain the significance of the 4 in the formatting string %4.2f.
float x;
x = 137.9397;
printf ("%4.2f" , x);
Thanks.
______________________________________________________________________________
Also just a quick side question, is the following definition valid?
int **p;
If it is could you please explain why? If not why?
I REALLY appreciate all this help.
Thankyou. :)
br0wn
572
float x;
x = 137.9397;
Thanks.
Result would be : 137.93
The format %4.2f means that you specify only to use 2 decimal digits
and 4 is the width (usually right-justified).
If you have a number = 3.223, printing with %5.2f
will generate : _3.22 ( the symbol _ is a blank symbol, thus
the number will occupy 5 spaces-- dot is counted as 1 space)
int **p;
Yes, it is valid.
It means that you define p to be a pointer that will hold address/pointer (instead of data).
That definition can be used to generate 2D array.
gittyup
5,036
I get 137.94 because of rounding.
