BOOLEAN is a binary type that returns 0 for FALSE, and anything else (typically 1) for TRUE. It is *not* a character-string. You *will* have to do some manipulation in order to associate the actual BOOLEAN values to text/string output.Originally posted by: ghidu
I want a boolean function to return true or false and not 1 or 0. I mean I'm printing the value and I want to look like "it's true" and not "it's 1". and I don't want to use IF in the main program.
Thanks
Maybe you can shed some light on this. The function is boolean and has to return "true" or "false"Originally posted by: cKGunslinger
Thanks
Yes, "logical" TRUE and FALSE, not the actual ascii characters T-R-U-E.Originally posted by: ghidu
Thanks
Let's just say it checks if a number is even or odd.Originally posted by: xtknight
Can you tell us what you are trying to accomplish with this or give us some background on the program you want to make?
Blech, Poor Programming Pratice...
I don't think there's any printf parameter that will print out "true" when a 0 or 1 is specified.
The "true" or "TRUE" you type in your code is replaced by a 1 when the program is compiled. Likewise the "false" and "FALSE" are replaced by a 0. The program doesn't know the difference between FALSE and 0.
This is all you need to do.
if (num%2) // or if string ends with 0,2,4,6,8->even, string ends with 1,3,5,7,9->odd. may save processing for large integers.
printf("number is odd\n");
else
printf("number is even\n");
else
Thanks guys, but what I have to do is print "The number is even - " TRUE ;or FALSE; (return of the boolean function.
result = functionThatReturnsBoolean();
printf ("The number is even: ");
if (FALSE == result)
printf(" FALSE. \n");
else
printf(" TRUE. \n");
char textArray[2][10];
textArray[0] = "FALSE\0";
textArray[1] = "TRUE\0;
printf ("The number is even: %s.\n", textArray[result] );
printf parametersOriginally posted by: ghidu
EDIT: actually I think there is a parameter for printf, but I'm using cout and I don't remember what parameter, it's been a long time.
else
What I asked is if there is a way to print the string TRUE insted of 1 from the value returned by the boolean function without an if/else because that I already knew how to do it and I didn't ask for help to modify the examples.
Originally posted by: itachi
it's best not to antagonize people who are trying to help you.
char *bstr [] = {"TRUE", "FALSE"};
int num;
printf ("The number if odd - %s", bstr[num & 1]);
printf ("The number is even - %s", bstr[(num + 1) & 1]);
Originally posted by: IHateMyJob2004
I read the thread.
THERE IS NO WAY TO PRINT "TRUE" OR "FALSE" IN C/C++ WITHOUT USING A CONDITIONAL OPERATION!
Sorry, but you seem to not be hearing what others have lready told you. Your only other option is to create a Boolean class and overload the operators in it to dispaly what you want.
c++ doesn't specify booleans as 1-bit values.. so '(int) check' could return 0xff for all you know, which would be sign-extended to -1.Originally posted by: TerryMathews
You could make a two-element array and typecast the bool into an int. Something like this:
bool check;
check = whatever();
string[2] validity {"True","False"};
cout << validity[(int)check];
Note this is not 100% compliant C++ code, you can do your own homework.
