ithehappy
I formatted the hard drive some weeks ago, and since the freshly installed Win 7 x64 installation I am noticing this weird problem! The space of C partition of the the hard disk is acting very weirdly. Just yesterday night when I went to sleep the free space was 8+ gigs or something and now its showing 1.5 gigs or something. No, nothing has been downloaded on the drive, you can rule out that option. One thing I noticed previously, as I download a lot via IDM, some files keep the cache space (or whatever the heck it is called) on the C partition, but I uninstalled IDM, and the space is still same!
The total disk space is 50 GB. If I select all the icons under that partition the total used space is 25.6 GB. Then virtual memory allocated for that partition is 8183 MB/ 8GB. So a total of 34-35 GB, so technically 14-15 GB should be free.
And the figure is changing rapidly too, in fact so fast that when I started to write this topic it showing 1.18 GB, but now it shows 1.06 GB.
Please tell me what's going on. Is there a way to see if there are other programs (apps) which are occupying the space somehow?
Thanks in advance.
Here are two screenshots as well:
This is my installed apps' list:
PS: I have run that Disk Cleanup thing for that partition, nothing noticeable there!
Thanks in advance.
