I'm having a problem with a C# program built with Visual Studio 2015 running on Windows 10. The program sends a message (a poll) on a serial port at 38400 baud to a device that replies with its status within 15 milliseconds. I have a timer to check for no response
timerAckTimeOut = new System.Timers.Timer();
I have two problems. With the ackTimeout interval set to 20 milliseconds and a poll rate of one poll every 10 milliseconds, I occasionally get spurious ack timeouts. Secondly, in the code below, the variable seq_ok is occasionally getting set to false yet when I display the values of b1 & b2 (via a queue) they are always the same so why is seq_ok getting set to false?
To take the serial comms out of the equation I replaced the serial port stuff with a timer interrupt that "pretends" a message has been received if the ack wait flag is set. With a poll rate of 10 milliseconds, a pretend receive timer rate of 4 milliseconds and an ack timeout of 20 milliseconds, I get quite a few ack timeouts. How accurate are System.Timers.Timer ?
Code:
private void ProcessReceivedMessage(byte[] buf, int numbytes)
byte[] local_buf = new byte[numbytes];
// copy the message because buf can be overwritten before this function finishes
// processing it
Buffer.BlockCopy(buf, 0, local_buf, 0, numbytes);
byte b1 = (byte)(local_buf[2] & 0x3f);
byte b2 = QBusSequenceNumber;
bool seq_ok = (b1 == b2);
lock(timerAckTimeOut)
if (WaitingForAck)
timerAckTimeOut.Stop();
WaitingForAck = false;
// qbus_AckRecv will call SendMessagesIfReady
if(AckRecv != null)
AckRecv(this, EventArgs.Empty);
if (seq_ok)
// whatever...
else
add_to_status_display_queue(String.Format("Seq #{0:d}: {0:d}", b1, b2));
