C++ <iomanip> problem.
d0ofy
1,404
I'm trying to output data in a table using a FOR loop. The first field is the Name, and I want it aligned left, so I use setiosflags(ios::left). The rest of the fields I want aligned right, so I used setiosflags(ios::right), but it still aligns left. I also tried resetiosflags(ios::right), and that doesn't work either. The whole table aligns left. Please help! Thanks.
mjquilly
1,692
You aren't outputting everything into the same column are you? Make sure to use setw(xx) before each field is output. ie:
cout << setiosflags(ios::left) << setw(10) << Name << setiosflags (ios::riht) << setw (10) << val1 << setw(10) << val2 << ........ << setw(10) << valn << endl;
d0ofy
1,404
That's exactly what I did.
Does it matter if the setiosflags() goes before the setw()? Or can I put the setw() before the setiosflags()?
mjquilly
1,692
I don't think it matters what order they go in, as long as you set your alignment before outputting the variable. The only other thing I can think of is to make sure you are making your column widths big enough.
cout << setiosflags(ios::left) << setw(8) << &quot;mjquilly&quot; << setiosflags(ios::right) << setw(2) << &quot;is&quot; << setw(7) << &quot;awesome&quot; << endl;
that would print:
&quot;mjquillyisawesome&quot;
d0ofy
1,404
That didn't work either.
But I figured it out. Instead of setiosflags(), I used cout.setf(ios::left), then unsetf(ios:left). Works perfectly.
Thanks a lot for your input though.
