C++ help with STL and sets
DaNorthface
343
Hi, i need some help working the STL set (sorted list). I'm trying to create a sorted list of objects, however, i'm not sure how to make the set know what data member to compare when sorting. I know i need something like set<Class_Name, compare> mySet; But i don't know how to implement 'compare' to make it compare the objects.
any help would be great. Thanks!
DaNorthface
343
thanks for the quick reply. It works, but i'm getting some error messages in ms visual 6 c++ /w sp5. Any ideas? This is how i used the set:
struct Event
int time; // Time of the event
int transaction;
}; // End Event
// this is just the header of ltstr , the implementation returns a bool
struct ltstr {
bool operator() (const Event&amp; lhs, const Event&amp; rhs);
set<Event, ltstr> eventList;
warning messages are:
C:\Documents and Settings\BartonMXP\My Documents\Project3\Bank.cpp(22) : warning C4786: 'std::pair<std::_Tree<Bank::Event,Bank::Event,std::set<Bank::Event,Bank::ltstr,std::allocator<Bank::Event> >::_Kfn,Bank::ltstr,std::allocator<Bank::Event> >::ite
rator,std::_Tree<Bank::Event,Bank::Event,std::set<Bank::Event,Bank::ltstr,std::allocator<Bank::Event> >::_Kfn,Bank::ltstr,std::allocator<Bank::Event> >::iterator>' : identifier was truncated to '255' characters in the debug information
C:\Documents and Settings\BartonMXP\My Documents\Project3\Bank.cpp(22) : warning C4786: 'std::pair<std::_Tree<Bank::Event,Bank::Event,std::set<Bank::Event,Bank::ltstr,std::allocator<Bank::Event> >::_Kfn,Bank::ltstr,std::allocator<Bank::Event> >::con
st_iterator,std::_Tree<Bank::Event,Bank::Event,std::set<Bank::Event,Bank::ltstr,std::allocator<Bank::Event> >::_Kfn,Bank::ltstr,std::allocator<Bank::Event> >::const_iterator>' : identifier was truncated to '255' characters in the debug information
c:\program files\microsoft visual studio\vc98\include\xtree(160) : warning C4786: 'std::_Tree<Bank::Event,Bank::Event,std::set<Bank::Event,Bank::ltstr,std::allocator<Bank::Event> >::_Kfn,Bank::ltstr,std::allocator<Bank::Event> >::_Tree<Bank::Event,B
ank::Event,std::set<Bank::Event,Bank::ltstr,std::allocator<Bank::Event> >::_Kfn,Bank::ltstr,std::allocator<Bank::Event> >' : identifier was truncated to '255' characters in the debug information
c:\program files\microsoft visual studio\vc98\include\utility(21) : warning C4786: 'std::pair<std::_Tree<Bank::Event,Bank::Event,std::set<Bank::Event,Bank::ltstr,std::allocator<Bank::Event> >::_Kfn,Bank::ltstr,std::allocator<Bank::Event> >::iterator
,bool>::pair<std::_Tree<Bank::Event,Bank::Event,std::set<Bank::Event,Bank::ltstr,std::allocator<Bank::Event> >::_Kfn,Bank::ltstr,std::allocator<Bank::Event> >::iterator,bool>' : identifier was truncated to '255' characters in the debug information
Linking...
I also did it using the following:
struct Event
int transaction; // -1 is departure, >= 0 is transaction time of arrival
bool operator< (const Event&amp; a) const
return (time < a.time);
}; // End Event
but that had more warning messages. Any ideas?
dighn
22,820
4
those are not errors and are expected when using STL in debug configuration in vc++ 6
you can disable it with a pragma directive if it gets really annoying
Barnaby W. Füi
12,343
"Before .NET, Microsoft stated that what they are creating is "a Windows compiler." Their interest was in creating a compiler that makes Windows programs, and not one that is compliant to the C++ Standard. As a result, the Standard C++ features in pre-.NET VC++ increased at a relative crawl, and you should not expect that compiler to compile many of the programs in the book." -- http://www.mindview.net/Books/TICPP/ThinkingInCPP2e.html#Compilers
translated: vc++ 6 sucks, if you are programming in modern c++ style.
