C++ getline/string need to input twice? arg!
michaelh20
482
I fixed the following by getting a string and getting the first char of the string... still is there a way to flush cin if I wanted to?
Also does anyone know of a good string tokenizer for c++ ? I like to input a bunch of numbers on a line and string tokenize it.. :)
I have the following code, which is supposed to get a line
and stick it in a string. There's a basic menu before this
that cin's a char to choose a menu option. What happens is I have to input the string twice or else it doesn't get anything at all. Does the cin of a char leave the rest of the input to muck up any other input? Or is there a way to flush cin so it doesn't keep stuff around?
the main menu inputs a char and then does something like:
switch(charChoice){
case 'h':
printMenu();
break;
case 'a':
addEntry();
break;
void addABunch() {
cout << (&quot;Gimme a bunch of numbers : &quot;);
string input;
getline(cin,input);
getline(cin,input); // had to do it twice...
cout << &quot;You gave me : &quot; << input << &quot;\n&quot;;
Nevyn522
208
Ah, I've seen this problem.
I don't remember exactly what caused it, but best guess is that the buffer isn't flushed, so your first input is actually the &quot;enter&quot; from the previous user input... I know there's a way to flush buffers, but I don't remember what it is.
If it's an option, you might want to look into using &quot;getch()&quot; ( I think that's it ) -- it will take a single character input only, but might be good enough for your purposes.
Good luck!
Andrew
2ndDawn
14
That's pretty much the best thing you can do...all getch() does is it pauses the program waiting for a button from the keyboard to be pressed.
PierreJ
<< getline(cin,input); >>
why are you using cin with the getline function??
You dont have to do all that
Here is the code
KISS - Keep It Small Simple
Updated Code:
void addABunch() {
string input;
cout << &quot;Gimme a bunch of numbers : &quot;;
cin >> input;
cout << &quot;You gave me : &quot; << input << endl;
Hope that helps
