C# Crew: Justin's weekly help me with my homework thread....
Jumpem
10,757
Is anyone familiar with setting upa factory model in C#?
I have to make a game of memory. the class with the game board uses strictly objects. It can not know whether the spaces are going to be strings, ints, or images.
I have to figure out how to use a factory model to do this.
Thanks! - Justin
Jumpem
10,757
That helps. Thanks.:)
I understand the model I think, but I am unsure how to go about it for my program.
Jumpem
10,757
Alright, I got this from my professor:
interface IFactory {
object create ( parameters );
Now, any implementation of IFactory has to implement create() but does not have to tell what it really creates.
If you need the created objects to do something (e.g., be a Control) simply say so in IFactory by changing the return type of create().
Jumpem
10,757
Originally posted by: torpid
Is that a question or an FYI?
the above post was an FYI.
I have a class with the factory interface:
public interface IFactory
object Create(object newObject);
Then I have the create function in my main:
public object Create(object newObject)
return newObject;
But then I am unsure what to do with that in regards to my model (logic for the game) class.
torpid
11,631
11
Hmm.. I think the idea is to have 3 factory classes, one that creates strings, one that creates integers, etc. It sounds a little weird but I don't know how else it would be done given the parameters you specified.
Jumpem
10,757
The professor siad that to change what type of object I want to just change the return type in the IFactory interface.
