C++ Code Help, Create Array based on file input matching criteria
kg4dsx
I am trying to get data from a tab delimited file(example of a few lines below). I want to count the number of authentications per hour. The first and fourth line is an example of a line I would want to count, the middle two are examples of other lines in the file that I want to ignore. The approach I am looking at is reading the first section and using the hour field as the address in the array.
int count = 0;
If (string contains "Successfully")
AuthCount[HourValue] = count ++
So the data below would result in
AuthCount[14]=1
AuthCount[15]=1
Any suggestions on how to write this?
2006-07-20 14:31:52 User.Info ServerIP Perfigo: Authentication:[User MAC ## User IP] username - Successfully logged in, Provider: authservername, L2 MAC address: User MAC
2006-07-20 14:31:52 User.Info ServerIP Perfigo: Administration:User MAC added to certified device list
2006-07-20 15:12:49 User.Info ServerIP Perfigo: Miscellaneous😱verwrote 1 logs in the past 10 minutes to keep the event log limit.
2006-07-20 15:31:52 User.Info ServerIP Perfigo: Authentication:[User MAC ## User IP] username - Successfully logged in, Provider: authservername, L2 MAC address: User MAC
Read in the line
Look for the string Authentication:
If string exists - continue parsing the data and use it.
Extract the time and turn it into a 24hour numeric value.
Truncate the time to only have an hour (ignore the minutes/seconds)
Use that as an index into the array of integers [24] witch then can be incremented
Otherwise - get next line of data
