- Apr 10, 2000
- 19,579
- 17
- 81
1997 Dodge Grand Caravan
3.3L v6
70k miles
Just got this van last week and noticed that the bypass hose (the rubber hose going from the engine down to the water pump) had a pin size hole in it and was streaming coolant out. I can easily remove the hose from up top but I can't get to the other end of the hose easily. The clamps they're using are the ones you squeeze with pliers to open them up. I can touch the clamp but theres no way I can get a pair of pliers down there without moving stuff out of the way (looks like the AC compressor is right in front of it) and I don't feel comfortable doing that at all.
My gripe is that I've gotten so many random estimates on how much the job is gonna cost. First I tried the dealer
Dealer1: $50 and about half an hour (yay?)
Dealer2: $128 and about 1.5 hours
Dealer3: $198 and about 1.5 hours
Dealer4: $400 and overnight (yikes!)
then I called up individual mechanics
Mech1: says I will need to get some sort of metal connector which only comes from the dealer. And he'll have to remove the AC compressor out of the way to make it easy for him so 2 hours minimum
Mech2: says he can probably do it in about an hour but that I had gotten the wrong size hose (went to NAPA and got a 2 foot long piece of 5/8" hose (Can't say for sure since I'm at work)) The mechanic claims that the hose that's needed has different sizes on each end (I think he said 5/8 on one end, 1/2 on the other?)
I'm going to take it to this old mechanic I used to go to years ago tomorrow (would have gone earlier but he's far from where I live now and I'll be in the area tomorrow).
I guess my question is, do any of those estimates/explanations sound right and how much work is it really?
TIA!
3.3L v6
70k miles
TIA!
