Dopekitten
So I've had the same computer for ~5 years now (I bought it roughly when the HD4xxx series was released). Unfortunately while it still works perfectly fine, it is is showing it's age a little more than I would like it to. For reference, my current computer is:
Q9450 @ 2.66ghz (I used to have it overclocked for the first year or so at ~3.6ghz, but not anymore, a bios crash or whatever caused me to lose my settings and i couldn't remember how to get it stable anymore, it's possible the CPU is also just not able to do it anymore).
HD4870 512mb (I used a 1920x1200 monitor and i definitely think that 512mb of VRAM is way too little)
8gb 1066mhz RAM (Used to have 4, but I needed more so I bought another 4gb a year ago or so)
Asus P5Q-E Motherboard
Seagate 7200.10 (?) HDD, (dunno, it's old, but I'm going to keep using it even if I upgrade)
P&PC 750W PSU
Antec 1200 case
With that in mind:
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
I play pretty much all games, and in general I'm not super picky about the graphics settings, but the constraints here are that I need to be play games even at medium settings 5 years down the line. I also like to have evreything open at the same time. For example, ideally what I would like (which I can't do right now) is to be able to have the list of stuff below all open at the same time in windowed mode so i can constantly alt-tab easily without lag: (All in 1920x1200 preferrably)
-a client of Dota2
-8 (yes 8, not a typo) clients of EVE Online
-a client of some other game, ranging from something smallish like Bastion to something more resource intensive like Skyrim
-2-3 instances of google chrome (with 20-30 tabs each)
-VLC running a video at 1920x1200
-Youtube video running in fullscreen
-Steam
-TS3
-Various other small things, notepad, task manager etc..., stuff that's pretty much inconsequential.
One thing I really hate is having to close and reopen stuff all the time because my computer can't handle it. I have pretty bad habits, with leaving stuff open, but preferably I'd like my computer to be able to handle it.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Under 700 USD, cheaper is better.
3. What country YOU will be buying YOUR parts from.
The US.
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
No preference
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Yes, I will be using my PSU, my case, my monitor, and my current hard drive (though that doesn't preclude using an SSD as well).
7. IF YOU plan on overclocking or run the system at default speeds.
Yes I'll overclock provided that it is extremely easy and that i can do it in a way where it won't impact my parts within a life-span of at least 4-5 years, i.e. running at roughly the stock voltage.
8. What resolution, not monitor size, will you be using?
1920x1200
9. WHEN do you plan to build it?
Between 1-2 weeks from now.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
No.
I've looked at similar threads and the suggested build at the top of this forum, and what I am basically considering is as follows:
http://pcpartpicker.com/p/1SM8N
Which is basically what the stickied thread says to buy. Unfortunately it's really more than I'd like to spend, and I'm not entirely sure if the parts I have there are overkill for what I want. Ideally I want parts such that 5 years from now, I will be in the same position. Computer still works perfectly fine, and does most of the things I want it to do fine, but can't play new games without significant compromises in quality--but still plays them above 60fps at roughly medium settings.
I definitely do want 16gb of RAM at least, and at least 2gb of VRAM. I've heard great things about SSD's, but I have no idea how to pick them (how do I tell which ones are good and which aren't outside of just $/gb), and I'm wondering if I should go with the 7950 or with something else like the 7870 or 7850 even for a really cheap price.
Thanks
P&PC 750W PSU
Antec 1200 case
With that in mind:
-a client of Dota2
-Steam
-TS3
The US.
No preference
1920x1200
No.
Thanks
