Aikouka
- Nov 27, 2001
- 30,383
- 912
- 126
I had my home inspection on the house that I'm buying.  Fortunately, there wasn't anything too major.  Probably the only big thing is a return pipe that looks like it has had some leakage occur above it, and it ended up on the visible portion of the pipe.
Although, one thing that I pointed out to the inspector were the extra supports in the crawlspace. There were the original supports in the middle, but it looks like someone added two extra rows of supports running parallel to the home. Well, while the original supports are poured + mortared, these newer ones do not appear to be poured and are definitely not mortared. I can't remember where I read about it, but what I read is that you do not do it that way. Whoever did it also took a lazy approach and pinned one of the copper pipes and wiring between a support beam and a joist.
Technically, is it an issue right now? No, because they still provide support, but I already saw a few of the blocks become misaligned, and that's all it takes. Seeing lazy work always gets me a bit worried as to what else could have been skimped on. :hmm:
 Facebook
Facebook Twitter
Twitter
