- Feb 22, 2008
- 2,846
- 4
- 81
http://www.newegg.com/Product/Produc...%2419%24%24%24
I need a new monitor for work anyway, and im running windows 8, so I might as well get a touch screen since its not that much more. I found both of these to have pretty decent reviews.
The 200 dollar one has a better score across the board than the 150, but the only difference i see on the spec sheet is that the 150 dollar one only works with windows 8 and 8.1. Since I plan on using it on windows 8 anyway, should I give that one a shot?
Also on a side note - now that chrome will run android apps, will it also allow you to use touch controls? If so im 100x more excited about getting a touch screen monitor.
