Buying a sound card looking for a recomendation.
Shadey216
16
Well i know this is pretty simple, but i'm looking to buy a new sound card for the comp i'm building. I had bought an Audigy 1 when it first came out for my current PC and i could not get the thing installed right. (This was also a while ago and over the past few years i've learned A LOT more about computer hardware) Creative Labs tech support was very helpfull with trying to help me get the thing installed correctly, but it never happened.
Anywase, i was thinking about getting an Audigy 2. The motherboard i'm going to be using is an Asus P4P800. I just want something that sounds real good for gaming and music. I'm going to be using a 4.1 speaker set up. Does anyone have any expereince with the p4p800 and the Audigy 2 on the same system and have any problems with them? Or can anyone recomend another sound card, maybee cheaper that would sound just as good?
D0S3D
i have the creative audigy 2 platinum ex and i have no regrets about that wat so ever i luv it LOL
i say at least get the platinum since most people now have a lot of mini disc players or mp3 .... but the platinum is also great for the dvds etc. so get the platinum not just the audigy 2
Nebor
29,582
12
I would not get the platinum unless your case is in a closed cabinet... cause that thing is ugly! Plus I don't see any use for any of it... seems silly to plug all those wires into the front of your computer...
ronnn
3,918
I have the p4p800 with an audigy 2, no problems easy install. Sounds great also. But if you still have the audigy 1, you can use hacked drivers from the audigy 2 and the sound difference would be very little.
Sureshot324
3,370
wait for the audigy 2 nx, should be out in a week or so. The M-Audio Revelution won't be as good for gaming and unless you are an audiophile i doubt you'd notice the difference in sound quality. It costs more too.
Ionizer86
5,292
The Santa Cruz may not be the best for gaming, but if you can get it for $6 (see Hot Deals) that's a steal and very much worth a try. (MSRP = $79.99).
