Question Buying a new M.2 drive, need some help
imported_blip
226
Like it says, I'm getting a new M.2 drive as my original one is not big enough. I've gotten confused about NVME, and whether I can use an NVME drive or not (or if it matters). Here is my mobo: https://www.gigabyte.com/Motherboard/B450M-DS3H-rev-10/sp#sp but I don't see anything about NVME mentioned.
On Amazon, for about the same price, are the Crucial P1, P2, and MX500 M.2 drives (about $55 for 500Gb). What's the difference? Which should I go for? Thanks!
damian101
291
107
86
"1 x M.2 connector (Socket 3, M key, type 2242/2260/2280/22110 SATA and PCIe x4/x2* SSD support)"
NVMe is just a protocol to directly access storage over PCIe, "PCIe SSD" is interchangable with "NVMe SSD".
So yes, that motherboard's M.2 slot supports NVMe SSDs.
Reactions: Ranulf
imported_blip
226
Ah that's why I didn't see "nvme" anywhere. Thanks!
gorobei
4,030
1,528
op has seemingly made his call.
for those in a similar quandry: m.2 is the form factor, nvme/sata is the protocol. nvme is faster than sata. and when buying you want to make sure the ssd has dram cache along with the basic nand. pcie3 is the good enough option for now, pcie4 only if you know you will be upgrading to a x570/b550 system (or whatever rocketlake platform) soonish.
imported_blip
226
Thanks, not upgrading my mobo anytime soon so sholdn't make much of a difference. I did read about he WD SN550 which doesn't have DRAM but some people said it still outperforms the SN750 is some cases. Either way, I spent the extra $7 on the SN750, and probably won't notice much performance change either way.
Also read something saying the M.2 form factor may be on its way out. Again, keeping my mobo for a while, so didn't really matter much to me. Can't quite justify an upgrage from my 1700X yet...
damian101
291
107
86
The M.2 NVMe / AHCI ports on the motherboard may also be connected to the SATA bus as well as the PCIe bus and therefore allow M.2 SATAs to also be inserted in the slot
motherboard has nvme m.2 but i got an deal on an sata m.2 , will this sata ssd work?
Yes, M.2 SATA SSDs will work in that slot.
Reactions: Bobsy
Ranulf
2,878
2,537
Just note that your motherboard may use up sata ports when you are using a sata m.2 drive. Check your motherboard manual.
Reactions: Bobsy
Bobsy
166
41
101
I'm upgrading to B550 and considered M.2 PCIe 4.0, but these drives are double the price of PCIe 3.0, so I was thinking better to go with a larger (or multiple) PCIe 3.0 drive than a smallish PCIe 4.0 drive. I assume I won't see the difference in real-life usage. Am I right?
gorobei
4,030
1,528
you wont see much of a difference unless you are using some special work application that demands a ton of bandwidth working with large files.
Reactions: Bobsy
