Which one do I get? What exactly is the difference between them? I'm planning on ordering this: http://www.directron.com/92l1a.html and I need to pick a Connector option.
2-pin is a non-standard connector that may not fit on anything. Some of the Panaflo fans come with that rather than bare leads.
3-pin is the type that connects to the headers on the motherboard.
4-pin is the type coming from your power supply, that plugs into hard drives and CDROM drives. This will have a pass-through connector so that you get power to the fan, but also still have a connector to use for another device rather than losing one.
Yeah, they all supply 12V. However the motherboard headers can't supply as much current. For a low speed Panaflo they're okay, but you wouldn't want to connect something like a Delta high speed fan because it would burn out the headers. Most "regular" speed fans or low speed fans are fine.
How can you tell if it's too much? I currently have 2 other 80mm fans hooked up (Panaflos, L1As I think) to the motherboard. Could I add a third Panaflo?
Yes, each header can take a certain amount. They are usually good for 3-4 watts, which I doubt the panaflo comes close to (don't feel like looking it up). If you're unsure or don't have spare 3-pin headers, get the 4-pin molex connector, which will pass through a power cable.
