I have a 4cyl 2000 Accord automatic. I was driving yesterday and then all of a sudden I heard some loud banging and the car slowed suddenly (good thing no one was behind me). I figured my transmission failed because the car would no longer shift into 3rd, it would jump back down to 1st which caused the car to slow down. Also, moving the shifter is a lot hard than before and the car vibrates a lot more. I talked to a friend who has the same car but a 2001 model and his had the same thing happen a couple years back. I didn't actually know this until I told him about my situation. He told me that he had to get his transmission replaced for $2000 but part of it was covered under the extended warranty since Accords of our generation have been having transmission problems frequently. Unfortunately mine is out of warranty. I called the dealer today and they gave me an estimate of $3700-4000 to replace the transmission. The KBB value for the car prior to transmission problem (private party, "fair" condition) is $3860. IDK if it's even worth it to fix the car.
Should I get the transmission replaced or should I sell/junk it and just get a another car? I can live without a car for at least a couple of weeks. Also, if it's best to sell it where could I go about doing so? Are there dealers that will take cars in my condition or do I need to go to a salvage yard and sell it for parts?
Thanks in advance
Update:
I called a few other shops. I live in a relatively small town so there aren't many to choose from. The cheapest to swap out for a remanufactured tranny was $2700, others were $3000+. A couple of them said they wouldn't even work on it since they only do domestic cars. I can't find a local shop that will rebuild it. There's reman trannies for $900-1000 on ebay though I'm not sure if I want to go through the trouble of buying one on ebay then bringing it to a shop to have it installed. I also asked some co-workers for advice but no one has any good suggestions.
Honestly, I kind of want to just get another car now. I'm young and single, I want something sporty 🙂 something like a VW GTI or similar. However, that's only if I can get a decent amount (more than a couple hundred $$) for the car as is.
Final update:
I sold the car to a repair shop/used card dealer for $900. I now drive this, a 2005 VW GTI 1.8T (Turbo) manual, and I LOVE it:
Thanks in advance
Update:
Final update:
