Busker is an Infrared Palm program to control Window's Winamp.
Sites: busker
winamp
palm files
I need some help.
Ok, so all the files are installed and everything has been reset and rebooted. When the time comes for the truth and I try to play winamp with the PalmPilot nothing happens...
Anyone else have this type of problem?
It would be interesting to get Busker to work with winamp.
Currently I have Win95a, I just want the PalmPilot to be the replacement for a monitor and keyboard. I also added a tweak to the windows shell to run Winamp as the shell. Goto C:\WINDOWS\SYSTEM.INI edit the "shell=explorer.exe" to "shell=winamp.exe". It takes some experimentation to get it right by moving files. Now Upon startup winamp will always be the shell.
Items needed to try it for yourself: a PalmPilot with infrared capabilities
Busker.prc... for the Palm
Irenhanc.zip... contains the files to update Ir on a Palm
Winamp... along with the "gen_buskerctl.dll" file
Here is a good example of a setup with busker
miata
Sites: busker
winamp
palm files
I need some help.
miata
