burning oil and also coolant?
Semidevil
3,017
so it appears that somewhere in my car, the engine oil is leaking. after driving about 3k miles, the dipstick is dry.
also, about every 2 days, I need to refill my car with coolant.
I check my car and I dont see any leakings under the car.
what/where could be the problem?
2002 nissan altima 4cyl
Greenman
21,699
6,137
Sounds like a blown head gasket to me. Is there water in the oil? Is the engine overheating?
Colt45
19,720
is there milky looking stuff floating on the antifreeze in the reservoir?
Vette73
21,503
9
How many miles and is there any leaks/wet spots on the ground? How does it run? Do you have a temp gauge?
Run the car with the rad. cap off and look for bubbles and also smell the coolant.
Semidevil
3,017
It's at 98k miles. It runs fine after I changed the spark plugs
Vette73
21,503
9
What did the plugs look like? color wise and any oil in the plug holes?
Best case you have a leak and it may be hitting the exhust and the oil could be leaking past the rings/valve stems and burning off.
Worse case bad head gasket/cracked block. Also you said the dipstick was dry. How much oil did it take to get back to the top of the line? And for coolant how much do ytou lose in a day or 2?
Crucial
5,026
But it's japanese. Shouldn't it last 500,000 miles and never have any problems?
andylawcc
18,183
all pointers seems to lead to cracked head gasket or head/block.
however, could it be two seperate incidents. One that leads to leaking/burning oil, and another independent one that leads to lost of coolant?
marvdmartian
5,441
27
You're not blowing a smoke screen out the tail pipe, like some wanna-be James Bond, are you??
Last time I saw that, it was so obvious the guy had a blown head gasket. At idle, little to nothing out the tail pipe. When the light turned green, and he hit the gas, everyone else at the light HAD to stop for ~30 seconds, until the fog/smoke that billowed out of his car cleared enough for everyone else to safely see the road again!! ;)
f1r3s1d3
534
Those cars have intake manifold gasket failures. I'm guessing thats it, considering it's burning coolant too.
Pacfanweb
13,155
59
There are oil passages in the intake?
