Burning Audio CDs in XP
Works for me...if you are trying to burn a CD, which programs are you using and which writer/re-writer do you have? If you could give us that information, we can help you a little bit better.
After you put a blank cd in,
it will prompt you what you want it to do.
After you drag & drop the files you want,
it should ask whether you want an audio or data cd.
It will open up Media player after you tell it audio.
You can then put the songs in the order you want.
Watch the little check-mark boxes.
I added one song & if the box isn't checked,
it won't burn it.
