First off look here.
That power supply that comes with the case is a beefy 500W and as you can see I also get a nice case compliments with 2 80mm fans. First of all, I have heard a lot of talk about making a silent PC. Well I have 2 Dell PCs a 533 and a 2.26 (my brother's) and I don't really find them noisy...so should I really be concerned with silence? This may sounds stupid, but are Dells known for being a silent or loud PC?
Anyways, aside from the fans I am also wondering if that power supply is good. The ratings on all the pipes are given on that page but I am not sure how reliable it is. It retails for around $80 CDN but with rebate I can get it for $50...
So to recap I am getting a potentially $180 case for $100 CDN. Are two or three 80 mm fans going to necessarily be noisy and is the power supply good enough to run a system with the following specs?
CPU -- AMD ATHLON64 3400+ 512K Socket 754 BOX (Newcastle)
Motherboard -- DFI Lanparty UT nF3 250Gb Socket 754 nVidia nForce3
Memory -- OCZ 2 x 512MB PC-3200 DDR400 Premier Series 1GB (2.5-3-3-7)
Video Card -- ATI All-In-Wonder Radeon X800XT / 256MB GDDR3 / AGP 8x
Sound Card -- Creative Labs Sound Blaster Audigy 2 ZS
Optical Storage -- NEC ND3520 (Silver) 16x DVD+/-R Writer 4X Double Layer DVD
HDD Storage -- Western Digital 74GB S-ATA, 10K RPM Raptor or Maxtor DMax10 7200 RPM S-ATA
