They got some possible screens of CPU-Z shot and also processor info.
What you guys think? legit?
Link Pcinlife
Link Pcinlife
I wonder why that person has 16gb of ram but is using a 32 bit OS which only allows 2.99gb usable.
The base frequency looks pretty low but the turbo is pretty high. I was expecting a minimum base of 3Ghz and above. I am 50/50 on whether this is legit or not.
I remember seeing some supposed benchmarks of them being at 1.8 GHz, which would be terrible, so I'm glad they're above it.
I see they have models according to that without any L3 cache, I wonder if they will then be replacing the Athlon II lines with a Athlon III line that's BD based, I kinda just expected them to shrink the Athlon II's to 32nm whenever they got around to it and they kept up with BD shipments. Or it could be to get better yields and use those otherwise no good dies.
Yes but Llano is Phenom II or K10.5 as people have called it before, they are not BD cores, I'm pretty sure they will have L3 cache as well.
Also, a lot of voltage for a 2.7ghz chip at over 1.4v.
Why do only 6 cores show up in CPUZ? Is there suppose to be a 6 core version of BD? I thought it was initially an 8 and a 4?
Completely different processor naming scheme than I've seen elsewhere!
