- May 19, 2004
- 32
- 0
- 0
I built a new system last night. When I boot it up, it doesn't seem to recognize or find the SATA HD that I've got plugged in.
1. The processor, the RAM in dual channel, and my two disc drives (one DVDRW and one DVDROM) are all recognized fine, and seem to be running perfectly. Likewise, my USB device (mouse) is recognized fine.
2. The system *knows* that a "Third Master Device" is plugged in... which, if I'm correct, is what the SATA drive plugged into the sata1 slot is supposed to be read as.
3. After identifying that there is a Third Master Device (and recognizing the master/slave DVDRW/DVDROM drives) it attempts to read the actually SATA drive, or something...
4. It flips to a screen that says "detecting IDE drive........". Now, shouldn't it says SATA drive? Or is this normal?
5. Regardless, it attempts to detect the drive, but it fails. It says something along the lines of nothing being installed/inserted "into the FastTrak.... BIOS is not installed".
6. Then, it flips back to the original boot screen, and it reads: "Error with Third Master Device... No Hard Drive detected".
7. After failing to detect the HD, it says that I can press F1 to continue on with setup. If I do press F1 the screens reads "Wait..." and seems to stall out for a long time. Perhaps I haven't waited long enough.
So, I'm looking for some help in getting my SATA drive recognized, so that I can load up an OS, and go from there... Eventually, I've got a secondary IDE HD to install as well.
Any help?
Thanks in advance,
Dave
Any help?
Thanks in advance,
Dave
