built new computer, wont work, help
realredpanda
205
i finished putting everything together, turned it on, everything lit up and the fans started going, but nothing happend, didn't post or goto bios or even beep, tryed hiting restart or power but that didn't turn it off so i hard to switch it off by turning off the powersupply.
my dad thinks its a bad cpu and i don't have any clue.
ASPIRE X-Infinity Red ATX Mid-Tower Case
DFI "LANPARTY UT nF3 250Gb" NVIDIA nForce3 250GB Chipset Motherboard For AMD Socket 754 CPU -RETAIL
eVGA nVIDIA GeForce 6800 Ultra Video Card, 256MB GDDR3, 256-bit, Dual DVI/TV-Out, 8X AGP, Model "256-A8-N345-AX" -RETAIL
AMD Athlon 64 3400+, 512k L2 Cache, The Only 64-bit Windows Compatible Processor - Retail
Corsair Value Select (Dual Pack) 184 Pin 512MBx2 DDR PC-3200 - OEM
NEC 16X Double Layer DVD±RW Drive, Black, Model ND-3520A BK, OEM
Seagate 200GB 7200RPM IDE Hard Drive, Model ST3200822A, OEM
580 watt powersupply, no brard that i can see, just called demon, bought from newegg
ts3433
2,731
Your PSU is almost certainly a POS.
Other than that, double-check your wiring, that things are installed securely, etc.
Sniper82
16,517
yeah try reseating memory and video. Also unhook everything but the CPU,memory and video. One last thing unplug the power and clear the CMOS or pull the BIOS battery out for about 30-60 secs.
Melchior
Banned
Sep 16, 2004
634
That PSU is a Powmax I believe. Not great, but atleast it should work.
No post is probably a bad CPU or board.
stevty2889
7,036
8
Yeah, that PSU is definatly a Powmax, I would not trust any system with that, they are quite possibly the worst PSU's made. I hada 400w version that blew and took my $180 motherboard with it. As for not getting a post, have you tried with the bare minimums? 1 stick of ram, cpu/heatsink fan, Video card(do you have another video card you can try, the power requirements of the 6800 ultra are probably far too much for that PSU to handle..) Why somebody would spend gobs of money on a top of the line video card, then get an extremely generic power supply is beyond me..
mechBgon
Oct 31, 1999
30,699
*jumps on "scummy-PSU" side of the teeter-totter :)
Especially with a 6800 Ultra. That ain't your father's Oldsmobile there, boy :evil:
realredpanda
205
tomorrow i'll unhook everything and try all that's been said, the case came with a 350 watt ps, and i have a old geforce i can stick in and see it works.
can anyone recommend a good power supply, one with lots of connecters for the 6800u to be happy with?
and if it still doesn't work how can you tell if it's the board or the cpu, or both?
