Just finished assembling a new PC.
Mobo: MSI 845PE MAX2.
CPU: Intel 3.06ghz w/hyperthreading.
RAM: 1gb (512mb DDR333, 512mb other).
HD: 20gb Maxtor, 60gb IBM.
HS/F: Zalman CNPS7000.
All parts are known working.
Those specs should help, for the time being.
I put the PC together, and tried to boot. No post. 🙁
So I start going through things, step by step, to try to figure out what might be wrong. Maybe the RAM sticks won't work together -- mixing DDR333 and 2700, I think. So I take one out. Try again. Still no luck. Tried the RAM in the first, second, and thks of RAM.no go in each slot. Tried both sticks of RAM (both known working).
Ok, next. I removed the IDE devices. Still no boot.
I have the diagnostic LED installed, but it doesn't stay on one color. It keeps rotating back & forth between several patterns, so I can't figure out exactly what is the problem. When I remove the RAM, it stops rotating, and just stops on the "bad ram" pattern. I hope this makes some sense.
This is what the LED pattern looks like (warning: 9mb mov file)
I'll work on getting pics up, so it isn't so huge.
Please help. I'd love to know how to get this damned system running. 🙂
Rob
Rob
