I just built a computer consisting of:
Abit KT7A mobo
1 GHz Athlon
32MB GeForce2 MX video card
... among other things, obviously. I made sure to use high quality components, such as a Taisol HS/fan, Arctic Silver compound, Enermax power supply, etc. The only "old" things I have are a stick of PC100 RAM (my only RAM -- not mixed with any new stuff or anything), a SoundBlaster 16 PCI, and an old ISA 56K modem (my only road to the net for now 🙁). To my knowledge, everything is installed perfectly fine.
Upon starting it up, I was able to install the newest VIA 4-in-1 drivers, nVidia drivers (23.11), etc. Everything seemed to be fine. However, after a day or two, problems started cropping up. I'm getting a fatal exception error every once in a while. The main problem seems to be some sort of video problem-- on the internet things will disappear. For example, I may be able to click on a link, but I won't be able to see it. Or I will scroll down and I will just leave tracers of what was on the bottom of the screen. And Madden 2001 won't work--it has some funky graphics that come up when I try and play.
Would different (older) nVidia drivers fix it? Or upgrading my BIOS? Or rearranging my modem and soundcard in different PCI/ISA slots? (I read something about that causing IRQ issues on the ABIT KT7 board).
Anyway, any help would be great. I'd love some advice before I go messing around with stuff I'm unsure of.
Thanks in advance,
WAZ
Abit KT7A mobo
1 GHz Athlon
Thanks in advance,
WAZ
